Post riepilogativo segnalato da ALFONE.(Elettronica)
ok domani provo, anche se non credo sia quello il problema, visto che ho verificato i fili dal connettore dell'impianto landi, ma non possiamo escludere niente. ho sentito anche di un modo per verificare se il collegamento del cavetto e' fatto bene, con hiperterminal ponticellando rx e tx. funziona? come si fa? per il momento grazie, a presto per aggiornamenti.
SI PUoi provare.... devi poi usare hyperterminal per testarlo
Loop-back Test Procedure for checking your Serial ports and/or USB - Serial Converter using HyperTerminal.
These instructions are for Win XP.
1. If you have a USB - Serial Converter, plug it in. You should check Device Manager to see if it is there first. Then proceed.
2. Go to Start - Programs - Accessories - Communications - HyperTerminal. In the box that comes up, type in a name, any name, like TEST. Click OK
3. In the Connect To window, at the bottom next to Connect Using: use the drop down menu to select the serial port you want to check - ie. COM 1. Make sure your modem is not selected! All the rest of your options on this screen will go away. Click OK
4. In the Com 1 Properties window, in the Flow Control drop down, Select NONE. Click OK.
5. You will now have a blank HyperTerminal screen. Click on File - Properties. Select the Setting Tab and at the bottom click on ASCII setup. Check the box next to Echo Typed Characters Locally. Click OK and OK again.
6. Now comes the tough part. You will need to jump pin #2 to #3 on your Male Serial Connector. The best way to do this is with a short wire with small alligator clips on each end. If you are good, you can do it with a paper clip or even a metal pen like a Cross Pen. Don't jump to any other pins! (If you look at your serial connector, there are 5 pins on top and 4 pins on the bottom, pins 1 - 5 are on the top and pins 6-9 are on the bottom. The pin orientation should read left to right as follows:
1 1 2---3 4 5
6 7 8 9
Pins 2-3 jumped. The pins are usually numbered on the plastic connector core that surrounds the pins.
7. With this accomplished, possibly with the help of a friend, start typing on your keyboard. Anything, numbers or letters.
  • Risposte 310
appena imposto da hiperterminal i parametri della porta, mi dice: "impossibile aprire com4. controllare le impostazioni della porta"
Sicuro che la porta sia giusta? E che non sia usata da un altro dispositivo? (es Bluetooth)
tu devi usare com1 ... non com4 !!!!
fatto, eseguito la procedura con porta com1 a 9600 ma il risultato e' lo stesso
Cerca una porta libera. Vai nell'elenco Periferiche o Dispositivi sotto Sistema -> Hardware, cerca le porte COM + LPT, e vedi quali sono già occupate.
infatti per quello usavo la porta com4, per provare il cavetto nel pc fisso. col portatile invece uso la com1 che e' libera, ma il messaggio e' sempre quello con hyperterminal
Controlla i bit di parity e stop se corrispondono.
Oppure, spesso e volentieri quando uso porte seriali per collegarmi ai decoder SAT, devo DISABILITARE il controllo flusso: prova anche tu.
Fatto, ma il problema é sempre quello
sbagli qualcosa e' evidente...
il cavo funziona, a patto di essere in grado di configurarlo correttamente
Io ho seguito alla lettera le tue istruzioni...
allora ricapitoliamo:
collego il cavetto, e verifico da gestione periferiche. qui lo vede come "Prolific usb to serial bridge" COM1
bit per secondo 9600
bit di dati 8
parita' nessuna
bit di stop 1
controllo flusso nessuno
imposto hyperterminal connettendo a COM1 facendo coincidere i parametri sopra elencati
risultato: IMPOSSIBILE APRIRE COM1. CONTROLLARE LE IMPOSTAZIONI DELLA PORTA
fatto, testato sia sul portatile che sul fisso, con porte com1 com3 e com5
sempre stesso risultato
TUTTI STI problemi non li ho mai avuti... i miei cavetti sono sempre andati al primo colpo.....
c'era solo da impostare com 1 e basta !!
