Quesito su Landi Omegas - sensore temper. acqua
Scusate, ma i forum sono fatti per condividere informazioni, se "parlate" in 3 o 4 lingue diverse precludete a molti utenti la comprensione... mandate messaggi privati che fate anche prima...
1. Temp. aqua per il cambio = 40 °
2. Ritardo passaggio benzina - gas: 10°= 50 s, .... 40°=40 s
It is mathematicaly unlogical:
1. when temp. is below 40, there is no change to gas
2. when temp. is 10, the change is after 50 s, at 40 after 40 s.
The first regulation is only for a cold startup, the second is for a warm startup.
How can the water temp. be 10 °C at warm startup?
I think there's a problem with your lambda probe, anyway i suggest you to enable the original engine temperature sensor, on the appropriate page of the omegs softwre.
I tried but only enabling it in SW without connecting cable to the engine temperature sensor is not enough.
Andrej
