codici autoradio renault
  • 1 month later...
Ciao a me serve il codice di questa autoradio per una renault scenic
Grazie
MODEL NO: 22DC278/62P
T0I938
RN278F20144924
PROD No: FD0102420144924
8200152346TI938
8200152346
code 8198
You must hold at the end to store your code.
IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
salve potrei avere il codice per questa autoradio renault megane?
code 2610
  • 8 months later...
