danielcre1 Postato 23 Aprile 2013 Report Share Postato 23 Aprile 2013 Ragazzi ho appena acquistato l'auto volevo mettere un'autoradio di serie mp3 ma la mia megane non è compatibile .. Ritorno al mio vecchio autoradio ma con il problema del code Model no:22DC257/62 Prod no:FD0303380049178 RN257F30049178 8200256140TQ027 Mi date una mano!! Grazie anticipatamente Link to comment Share on other sites More sharing options...
hay88 Postato 23 Aprile 2013 Report Share Postato 23 Aprile 2013 Ragazzi ho appena acquistato l'auto volevo mettere un'autoradio di serie mp3 ma la mia megane non è compatibile .. Ritorno al mio vecchio autoradio ma con il problema del code Model no:22DC257/62 Prod no:FD0303380049178 RN257F30049178 8200256140TQ027 Mi date una mano!! Grazie anticipatamente code 9990 You must hold at the end to store your code. IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code FOR NO STEERING CONTROL press the first preset button for the 1st digit, second button for the 2nd digit third button for 3rd digit forth button for 4th digit then press and HOLD button 6 to store. for 10 seconds and on some it's hold 5 to store. note the radio does not lockout after a wrong code entry it only doubles the time to wait before the next retry...if a wrong code is entered it will display error then after the delay should display "0000") Link to comment Share on other sites More sharing options...
giorgiofer Postato 23 Aprile 2013 Report Share Postato 23 Aprile 2013 Chiunque volesse avere il codice mandi una mail all’indirizzo cancellato - SPAM con il seriale della radio BAN 6 mesi Link to comment Share on other sites More sharing options...
GrossoTorre Postato 24 Aprile 2013 Report Share Postato 24 Aprile 2013 Buongiorno a tutti scrivo dall'officina Grosso & Torre, avrei bisogno del code radio del seguente stereo BLAUPUNKT codice BP9372Y3673376 FIAT PUNTO LOW 7649372316. VI RINGRAZIO IN ANTICIPO PER L'ATTENZIONE Link to comment Share on other sites More sharing options...
pao81 Postato 24 Aprile 2013 Report Share Postato 24 Aprile 2013 Chiunque volesse avere il codice mandi una mail all’indirizzo cancellato - SPAM con il seriale della radio Come già ricordato numerose volte e preso altrettanti provvedimenti ribadisco ancora una volta che la pubblicazione di mail è proibita. Una nuova violazione comporterà il BAN. Per le richieste dei codici delle autoradio utilizzate il forum come fanno tutti Link to comment Share on other sites More sharing options...
hay88 Postato 24 Aprile 2013 Report Share Postato 24 Aprile 2013 Buongiorno a tutti scrivo dall'officina Grosso & Torre, avrei bisogno del code radio del seguente stereo BLAUPUNKT codice BP9372Y3673376 FIAT PUNTO LOW 7649372316. VI RINGRAZIO IN ANTICIPO PER L'ATTENZIONE code 2342 Link to comment Share on other sites More sharing options...
GrossoTorre Postato 26 Aprile 2013 Report Share Postato 26 Aprile 2013 Grazie Mille.. Link to comment Share on other sites More sharing options...
axelmon Postato 29 Aprile 2013 Report Share Postato 29 Aprile 2013 Salve, ho perso il codice della mia radio, il modello è Delco CDR500(E) No 09136107 Supplier 4660103MH è possibile avere il codice di sblocco. Grazie a tutti Link to comment Share on other sites More sharing options...
bisi Postato 29 Aprile 2013 Report Share Postato 29 Aprile 2013 sono nuovo e avrei tanto bisogno di sbloccare la mia autoradio becker BE7910 serial 45006129 GRAZIE Link to comment Share on other sites More sharing options...
hay88 Postato 30 Aprile 2013 Report Share Postato 30 Aprile 2013 sono nuovo e avrei tanto bisogno di sbloccare la mia autoradio becker BE7910 serial 45006129 GRAZIE code 63513 Link to comment Share on other sites More sharing options...
cm4nazy Postato 30 Aprile 2013 Report Share Postato 30 Aprile 2013 mandatemi il seriale dell' autoradio e io vi mando i cod. meglio di cosii???? Gentili Utenti, vista la mole di segnalazioni errate ai moderatori vi ricordiamo che per rispondere ad un post è necessario cliccare sul pulsante ADD REPLY posto in fondo alla pagina sul lato destro . Il pulsante REPORT al contrario va utilizzato soltanto per segnalazioni di tipo disciplinare o tecnico ai Moderatori, che lo ricordiamo NON SONO IN POSSESSO DI INFORMAZIONI RELATIVE AI CODICI AUTORADIO SMARRITI Grazie Lo Staff Ciao ho comprato una opel agila non ho il codice radio l'ho richiesto all'opel ma non si puo' avere perchè la radio è stata montato dopo l'acquisto,se puoi darmi una manoi seriali sono 9012 300 00282 00 003 0333 2569480,grazie Link to comment Share on other sites More sharing options...
axelmon Postato 30 Aprile 2013 Report Share Postato 30 Aprile 2013 Salve, ho perso il codice della mia radio, il modello è Delco CDR500(E) No 09136107 Supplier 4660103MH è possibile avere il codice di sblocco. Grazie a tutti forse mancava qualcosa GM1500X9158249 Link to comment Share on other sites More sharing options...
denver1979 Postato 30 Aprile 2013 Report Share Postato 30 Aprile 2013 Salve ragazzi, ho bisogno del vostro aiuto...Ho smarrito la card con il codice della mia autoradio della lancia Ypsilon del 2005.. Mi potreste gentilmente aiutare? i codici sono: nr 7645302316 fiat nr 7453925540 Grazie mille! Manca il seriale a 12 cifre dopo il BP tipo BP5302*1234567... salve ho bisogno del code della mia radio bp:338830860672 n° 7 643 388 316 grazie!!!! Link to comment Share on other sites More sharing options...
hay88 Postato 30 Aprile 2013 Report Share Postato 30 Aprile 2013 Salve ragazzi, ho bisogno del vostro aiuto...Ho smarrito la card con il codice della mia autoradio della lancia Ypsilon del 2005.. Mi potreste gentilmente aiutare? i codici sono: nr 7645302316 fiat nr 7453925540 Grazie mille! Manca il seriale a 12 cifre dopo il BP tipo BP5302*1234567... salve ho bisogno del code della mia radio bp:338830860672 n° 7 643 388 316 grazie!!!! code 4246 Link to comment Share on other sites More sharing options...
lemmark Postato 2 Maggio 2013 Report Share Postato 2 Maggio 2013 Ciao raga, ho rimediato tutti i dati :-) opel corsa 2 serie radio originale Philips DC 347 Model no. 22 DC 347/78 PROD NO: FD 0997349049307 se qualcuno sa il code (perso anni fa) grazieeeeeeeeeeeeeeeeeeeeeeeeeeeee Link to comment Share on other sites More sharing options...
