niele74 0 Postato 18 Novembre 2011 Report Share Postato 18 Novembre 2011 Hi all, after changing the Doblò battery of my company, now the radio integrated is locked, but we no longer find the card codes (our fault, we bought the vehicle new in 2004 ....) I kindly ask help in the forum, posting all the serial numbers in the hope that someone can help me (the delivery guy gets bored when out...) Data radio: MOD. CD SW DUCATO NSB Vers.1.3 BP NR 7643318316 PROD. NR FIAT 735388373 Bar code. 56470018622 Thanks in advance! For more info are here .. Daniele P.S. at the moment I haven't found any code like xBPxxxxxxx stamped in to the metal casing you will fin BP3318*1234567 OK, I found it! Over the years the label came off and fell in the radio compartment Thank you very much 815BP331841174913 Link to post Share on other sites
peppinopalermo 0 Postato 18 Novembre 2011 Report Share Postato 18 Novembre 2011 SALVE HO BISOGNOUN PICCOLO AIUTO SERVIREBBE UN CODICE SBLOCCO .SERIE OB735296997 MODELLO MO33719 END 92540. SALUTI E A PRESTO GIUSEPPE Link to post Share on other sites
hay88 0 Postato 18 Novembre 2011 Report Share Postato 18 Novembre 2011 Hi all, after changing the Doblò battery of my company, now the radio integrated is locked, but we no longer find the card codes (our fault, we bought the vehicle new in 2004 ....) I kindly ask help in the forum, posting all the serial numbers in the hope that someone can help me (the delivery guy gets bored when out...) Data radio: MOD. CD SW DUCATO NSB Vers.1.3 BP NR 7643318316 PROD. NR FIAT 735388373 Bar code. 56470018622 Thanks in advance! For more info are here .. Daniele P.S. at the moment I haven't found any code like xBPxxxxxxx stamped in to the metal casing you will fin BP3318*1234567 OK, I found it! Over the years the label came off and fell in the radio compartment Thank you very much 815BP331841174913 code 2451 Link to post Share on other sites
hay88 0 Postato 18 Novembre 2011 Report Share Postato 18 Novembre 2011 SALVE HO BISOGNOUN PICCOLO AIUTO SERVIREBBE UN CODICE SBLOCCO .SERIE OB735296997 MODELLO MO33719 END 92540. SALUTI E A PRESTO GIUSEPPE code 5697 Link to post Share on other sites
niele74 0 Postato 18 Novembre 2011 Report Share Postato 18 Novembre 2011 Hi all, after changing the Doblò battery of my company, now the radio integrated is locked, but we no longer find the card codes (our fault, we bought the vehicle new in 2004 ....) I kindly ask help in the forum, posting all the serial numbers in the hope that someone can help me (the delivery guy gets bored when out...) Data radio: MOD. CD SW DUCATO NSB Vers.1.3 BP NR 7643318316 PROD. NR FIAT 735388373 Bar code. 56470018622 Thanks in advance! For more info are here .. Daniele P.S. at the moment I haven't found any code like xBPxxxxxxx stamped in to the metal casing you will fin BP3318*1234567 OK, I found it! Over the years the label came off and fell in the radio compartment Thank you very much 815BP331841174913 code 2451 Thank you Hay, I try it and I inform you if work well Link to post Share on other sites
hay88 0 Postato 18 Novembre 2011 Report Share Postato 18 Novembre 2011 Hi all, after changing the Doblò battery of my company, now the radio integrated is locked, but we no longer find the card codes (our fault, we bought the vehicle new in 2004 ....) I kindly ask help in the forum, posting all the serial numbers in the hope that someone can help me (the delivery guy gets bored when out...) Data radio: MOD. CD SW DUCATO NSB Vers.1.3 BP NR 7643318316 PROD. NR FIAT 735388373 Bar code. 56470018622 Thanks in advance! For more info are here .. Daniele P.S. at the moment I haven't found any code like xBPxxxxxxx stamped in to the metal casing you will fin BP3318*1234567 OK, I found it! Over the years the label came off and fell in the radio compartment Thank you very much 815BP331841174913 code 2451 Thank you Hay, I try it and I inform you if work well your welcome Link to post Share on other sites
niele74 0 Postato 18 Novembre 2011 Report Share Postato 18 Novembre 2011 Hi all, after changing the Doblò battery of my company, now the radio integrated is locked, but we no longer find the card codes (our fault, we bought the vehicle new in 2004 ....) I kindly ask help in the forum, posting all the serial numbers in the hope that someone can help me (the delivery guy gets bored when out...) Data radio: MOD. CD SW DUCATO NSB Vers.1.3 BP NR 7643318316 PROD. NR FIAT 735388373 Bar code. 56470018622 Thanks in advance! For more info are here .. Daniele P.S. at the moment I haven't found any code like xBPxxxxxxx stamped in to the metal casing you will fin BP3318*1234567 OK, I found it! Over the years the label came off and fell in the radio compartment Thank you very much 815BP331841174913 code 2451 Thank you Hay, I try it and I inform you if work well your welcome YES!! work perfectly!! thanks^2 Link to post Share on other sites
hay88 0 Postato 18 Novembre 2011 Report Share Postato 18 Novembre 2011 Hi all, after changing the Doblò battery of my company, now the radio integrated is locked, but we no longer find the card codes (our fault, we bought the vehicle new in 2004 ....) I kindly ask help in the forum, posting all the serial numbers in the hope that someone can help me (the delivery guy gets bored when out...) Data radio: MOD. CD SW DUCATO NSB Vers.1.3 BP NR 7643318316 PROD. NR FIAT 735388373 Bar code. 56470018622 Thanks in advance! For more info are here .. Daniele P.S. at the moment I haven't found any code like xBPxxxxxxx stamped in to the metal casing you will fin BP3318*1234567 OK, I found it! Over the years the label came off and fell in the radio compartment Thank you very much 815BP331841174913 code 2451 Thank you Hay, I try it and I inform you if work well your welcome YES!! work perfectly!! thanks^2 your welcome glad to help Link to post Share on other sites
vitostrusi 0 Postato 21 Novembre 2011 Report Share Postato 21 Novembre 2011 Ciao stilo, avrei bisogno anch'io del codice per sbloccare la mia autoradio. Si tratta dell'apparato montato di serie sulla mia jeep cherooke del 2004, penso sia marca clarion. L'ho smontata e i codici che vi sono scritti sono i seguenti: (Modell P05091650AB) (SERIAL NUMBER T 00 AM 070 4 M0044). Ti ringrazio in anticipo, Vito. Link to post Share on other sites
peppinopalermo 0 Postato 21 Novembre 2011 Report Share Postato 21 Novembre 2011 salve avrei bisogno di un codice sblocco per un autoradio fiat stilo. dati autoradio: ob735296997 mod mo33719 end.92540, grazie ,giuseppe Link to post Share on other sites
hay88 0 Postato 21 Novembre 2011 Report Share Postato 21 Novembre 2011 salve avrei bisogno di un codice sblocco per un autoradio fiat stilo. dati autoradio: ob735296997 mod mo33719 end.92540, grazie ,giuseppe code 5697 or 4196 Link to post Share on other sites
casadelfanale 0 Postato 21 Novembre 2011 Report Share Postato 21 Novembre 2011 Salve, ho una autoradio suppongo alpine bloccata montata su mercedes classe a. Codice e modello: MF2910 sn 2910 3 06 44691 anticipatamente ringrazio Luigi Link to post Share on other sites
hay88 0 Postato 23 Novembre 2011 Report Share Postato 23 Novembre 2011 Salve, ho una autoradio suppongo alpine bloccata montata su mercedes classe a. Codice e modello: MF2910 sn 2910 3 06 44691 anticipatamente ringrazio Luigi sorry for your model Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM Link to post Share on other sites
Marco_vectra 0 Postato 26 Novembre 2011 Report Share Postato 26 Novembre 2011 ciao a tutti, ragazzi ho un problemino, come quasi tutti qui, ho sostituito la batteria alla mia auto (opel vectra del 2000) e non ho più il codice della radio. i dati della radio sono: PHILIPS CAR400 SERIAL: GM0400Y2770587 POI CE UN ETICHETTA DOVE DICE NO: 09136106 TYPE: CAR400 2F3 RICORDO SOLO CHE IL CODICE ERA DI 4 CIFRE SE NON SBAGLIO.. POTETE AUITARMI??? GRAZIE IN ANTICIPO. Link to post Share on other sites
Guest Carmelo66 Postato 26 Novembre 2011 Report Share Postato 26 Novembre 2011 mandatemi il seriale dell' autoradio e io vi mando i cod. meglio di cosii???? Gentili Utenti, vista la mole di segnalazioni errate ai moderatori vi ricordiamo che per rispondere ad un post è necessario cliccare sul pulsante ADD REPLY posto in fondo alla pagina sul lato destro . Il pulsante REPORT al contrario va utilizzato soltanto per segnalazioni di tipo disciplinare o tecnico ai Moderatori, che lo ricordiamo NON SONO IN POSSESSO DI INFORMAZIONI RELATIVE AI CODICI AUTORADIO SMARRITI Grazie Lo Staff ciao ho un alfa 166 ed ho perso il cartellino con i codici mi potresti aiutare? Link to post Share on other sites
