hay88 Postato 7 Ottobre 2014 Report Share Postato 7 Ottobre 2014 Hello everyone, I bought a used car citroen saxo 2000 a station wagon, Unfortunately, removing the battery of the car I found that the radio, I state that it is an old model as there is still the gateway to the cassette, no longer works and that serves to restore a 4-digit unlock code. The former owner does not remember this code, I tried to search the internet if there was a way to get it for free and I saw that here you have solved many problems similar to mine. I'll give you the codes that I have behind my radio: Code: 900109087156 Model: No. 22rc200 / 35 and there is also this: phf9087156 Hoping that some of you can help me, I thank you in advance. please post the security code like TOT123 Hello everyone, I bought a used car citroen saxo 2000 a station wagon, Unfortunately, removing the battery of the car I found that the radio, I state that it is an old model as there is still the gateway to the cassette, no longer works and that serves to restore a 4-digit unlock code. The former owner does not remember this code, I tried to search the internet if there was a way to get it for free and I saw that here you have solved many problems similar to mine. I'll give you the codes that I have behind my radio: Code: 900109087156 Model: No. 22rc200 / 35 and there is also this: phf9087156 Hoping that some of you can help me, I thank you in advance. Please post the security code like TOT123 You will find it just below the first barcode Ciao, il codice di sicurezza è TOJ736 grazie mille. Hi, the security code is TOJ736 Thanks. code 6513 Link to comment Share on other sites More sharing options...
claudiano79 Postato 7 Ottobre 2014 Report Share Postato 7 Ottobre 2014 Ciao ho un problema con la mia radio fiat 500 bp ti invio i cod seriali Bp 638381931197 Fiat 312 mp3 SB05 7646383316 Grazie e spero possa aiutarmi. Link to comment Share on other sites More sharing options...
Ganz Postato 7 Ottobre 2014 Report Share Postato 7 Ottobre 2014 Hello everyone, I bought a used car citroen saxo 2000 a station wagon, Unfortunately, removing the battery of the car I found that the radio, I state that it is an old model as there is still the gateway to the cassette, no longer works and that serves to restore a 4-digit unlock code. The former owner does not remember this code, I tried to search the internet if there was a way to get it for free and I saw that here you have solved many problems similar to mine. I'll give you the codes that I have behind my radio: Code: 900109087156 Model: No. 22rc200 / 35 and there is also this: phf9087156 Hoping that some of you can help me, I thank you in advance. please post the security code like TOT123 Hello everyone, I bought a used car citroen saxo 2000 a station wagon, Unfortunately, removing the battery of the car I found that the radio, I state that it is an old model as there is still the gateway to the cassette, no longer works and that serves to restore a 4-digit unlock code. The former owner does not remember this code, I tried to search the internet if there was a way to get it for free and I saw that here you have solved many problems similar to mine. I'll give you the codes that I have behind my radio: Code: 900109087156 Model: No. 22rc200 / 35 and there is also this: phf9087156 Hoping that some of you can help me, I thank you in advance. Please post the security code like TOT123 You will find it just below the first barcode Ciao, il codice di sicurezza è TOJ736 grazie mille. Hi, the security code is TOJ736 Thanks. code 6513 il codice funziona! Grazie mille! the code works! Thank you very much! Link to comment Share on other sites More sharing options...
marcoc9998 Postato 9 Ottobre 2014 Report Share Postato 9 Ottobre 2014 Salve a tutti mi chiamo Marco..sono nuovo del forum...ho appena acquistato una fiat multipla usata ma il vecchio proprietario non trova il codice di sblocco dell'autoradio...chissa' se qualcuno di voi mi puo' aiutare BP nr. 7646325316 Fiat nr. 7354360610 Fiat 186 CD SB 05 Spero di essermi presentato in modo corretto Link to comment Share on other sites More sharing options...
genny_c Postato 9 Ottobre 2014 Report Share Postato 9 Ottobre 2014 Salve a tutti, sono anch'io nuovo del forum ed ho un problema con la mia fiat stilo e spero che qualcuno di voi possa aiutarmi.Ho comprato l'auto usata da pochi mesi e avendo in dotazione una radio con vano cassetta ero alla ricerca di una radio con lettore. Sfortunatamente dopo aver trovato quello che credevo fosse un'occasione ( dopo aver smontato tutto mi sono accorto che il lettore cd non funzionava correttamente) ho dovuto rimontare lo stereo a cassetta. Purtroppo non ho il codice dello stereo e non so come recuperarlo. SERIAL NO. M145809VISTEON PART NO. 2FCF-18C838-KAMODEL OAFIAT PART NO. 735374217Vi ringrazio in anticipo e spero che possiate fare qualcosa . Link to comment Share on other sites More sharing options...
andreabaratta1974 Postato 9 Ottobre 2014 Report Share Postato 9 Ottobre 2014 salve a tutti sono nuovo mi trovo con lo stereo della mia ka smarrito questo è il numero seriale M033189 qualcuno mi aiuta grazie Link to comment Share on other sites More sharing options...
claud0072 Postato 10 Ottobre 2014 Report Share Postato 10 Ottobre 2014 Ciao piacere Claudio scusa il disturbo mi servirebbe il codice radio di una rcd 510 vw pensi sia possibile e cosa devo fornirti per averlo ti ringrazio tantissimo Link to comment Share on other sites More sharing options...
brazoni Postato 10 Ottobre 2014 Report Share Postato 10 Ottobre 2014 Buongiorno, purtroppo ho smarrito il codice della radio blaupunkt e avendo cambiato la batteria dell'autovettura non riesco più a fare funzionare la radio con nav del Nissan qashqai e sono disperato, l'ho smontata e il codice di serie é il seguente: CM 00 22 A 3078593 Nissan LCN 76 12 830 022 Ringrazio in anticipo per la cortese disponibilità e professionalità. Link to comment Share on other sites More sharing options...
claud0072 Postato 10 Ottobre 2014 Report Share Postato 10 Ottobre 2014 Ciao sono sempre Claudio per recuperare il codice sblocco del mio RCD 510 posso andare bene questi dati sempre se possibile . -VWZ1Z3M8217337 - TANTE GRAZIE E SCUSA ANCORA IL DISTURBO Link to comment Share on other sites More sharing options...
hay88 Postato 12 Ottobre 2014 Report Share Postato 12 Ottobre 2014 Salve a tutti, sono anch'io nuovo del forum ed ho un problema con la mia fiat stilo e spero che qualcuno di voi possa aiutarmi. Ho comprato l'auto usata da pochi mesi e avendo in dotazione una radio con vano cassetta ero alla ricerca di una radio con lettore. Sfortunatamente dopo aver trovato quello che credevo fosse un'occasione ( dopo aver smontato tutto mi sono accorto che il lettore cd non funzionava correttamente) ho dovuto rimontare lo stereo a cassetta. Purtroppo non ho il codice dello stereo e non so come recuperarlo. SERIAL NO. M145809 VISTEON PART NO. 2FCF-18C838-KA MODEL OA FIAT PART NO. 735374217 Vi ringrazio in anticipo e spero che possiate fare qualcosa . try code 5428 Code Entry as Follows: Switch Radio On - Display Shows CODE with " - - - - " flashing Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press " SELECT " to Enter Link to comment Share on other sites More sharing options...
giuseppe94 Postato 14 Ottobre 2014 Report Share Postato 14 Ottobre 2014 Salve sono un nuovo utente ho lo stesso problema degli altri ho una fiat punto 188 del 2001 con autoradio a cassette, ho estratto l'autoradio e dietro ci sono i seguenti dato: Bp-nr 7649372316 Prod.nr.fiat 735272569 Link to comment Share on other sites More sharing options...
Erika86 Postato 14 Ottobre 2014 Report Share Postato 14 Ottobre 2014 BP5384 6 9486523 7645384318 nissan micra 2006 aiutooo pleaseeee !! Grazie milleee x la tua disponibilità Link to comment Share on other sites More sharing options...
Erika86 Postato 14 Ottobre 2014 Report Share Postato 14 Ottobre 2014 BP5384 6 9486523 7645384318 nissan micra 2006 aiutoooo sono nuova non so manco dove si rispondeeé... aiutamiii x favoreee grazie x la tua disponibilità spero mi aiuterai al più presto Link to comment Share on other sites More sharing options...
costinator95 Postato 16 Ottobre 2014 Report Share Postato 16 Ottobre 2014 Salve sono nuovo nel forum , sto impazzendo , avrei bisogno del codice per sbloccare la mia autoradio , il seriale inciso sulla scocca metallica della mia CDR 2005 è : GM020532766128 . Grazie mille in anticipo.. Link to comment Share on other sites More sharing options...
Alexxino29 Postato 16 Ottobre 2014 Report Share Postato 16 Ottobre 2014 Salve puoi recuperarmi un codice radio rcd 510 blaupunk? Vw3c8035195 bp-7 647239360 Link to comment Share on other sites More sharing options...
