se vi servono i cod. radio vi posso aiutare io!!!!
marcobiondo2006
salve sono nuovo del forum purtroppo o perso
il codice della mia radio blaupunkt mi potete aiutare
ecco i codici:
39101-86G10-GRY
ID 39101-85G1
codici a bare 5 7306991 7644061510
auto suzuky ignis
se potete auitarmi poike il concessionario
dove lo presa mi a kiesto 70 euro
colgo l occasione e porgo cordiali saluti :angry:
code 1462
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press and Hold "BAND"
The display will now show " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press and Hold "BAND" to Enter
  • Risposte 4,8k
sei stato gentilissimo e ti ringrazio!
ma visto che io non ne capisco nulla, mi saprebbe dire cosa vol dire la scritta CANCHECK sul display?
If you are trying to fit this radio to a different vehicle, then you may find yourself with the Error message of "CANCHECK". As well as having a conventional Radio Security Code number, this stereo is also electronically paired, or "Married" to the engine management system of the vehicle it came out of using very sophisticated CAN-BUS system technology.
When it is first powered up, it will communicate with the vehicle, and a message of "WAIT" will appear on the display whilst this process is in operation. If communication has been successfull, it will prompt for the Code number to be entered in the normal way.
However, if removed and refitted into a different vehicle other than the original one, it will not recognise the encrypted CANBUS identification of the new car, and will instead display an error message of "CANCHECK".
This Radio cannot therefore be transferred from one car to another, unless it has first been reset back into its original "Delivery Mode" with the CAN-BUS data memory reprogrammed for use with the new vehicle.
Se si sta tentando di adattare questa radio a un veicolo diverso, allora potreste trovarvi con il messaggio di errore "CANCHECK". Oltre ad avere un numero convenzionale di sicurezza Radio codice, questo stereo è abbinato anche elettronicamente, o "Married" al sistema di gestione del motore del veicolo è uscito di utilizzare molto sofisticata tecnologia CAN-BUS sistema.
Prima volta che viene acceso, si comunica con il veicolo, e un messaggio di "WAIT" apparirà sul display, mentre questo processo è in funzione. Se la comunicazione ha avuto successo, sarà richiesto il numero di codice da inserire in modo normale.
Tuttavia, se rimosso e rimontato in un veicolo diverso diverso da quello originale, non riconosce l'identificazione cifrato CANBUS della nuova vettura, e invece visualizzato un messaggio di errore di "CANCHECK".
Questa radio non possono quindi essere trasferiti da una vettura all'altra, a meno che non sia stata resettato di nuovo nella sua originale "Modalità di consegna" con il CAN-BUS memoria dati riprogrammato per l'uso con il nuovo veicolo
salve, sono disperata! ho acquistato una corsa usata 1.2 twin port con dentro una radio cd30 mp3. ahime dopo aver acquistato l'auto mi accorgo che sul display mi compare la micidiale scritta "display safe". ho letto e seguito tante istruzioni ma non mi compare mai la possibilità di inserire nessun codice (che per altro non conosco). questo vuol dire che il vecchio proprietario o chi per lui ha bloccato completamente la radio? inoltre a guardare il colore della radio e della plancia non credo neanche sia l'originale! alla opel non sanno farci nulla...ma credo più per superficialita. qualcuno di voi esperti sa dirmi qualcosa...aiutatemi vi prego.
abbracci
annat70
Salve mi presento sono Giacomo dopo circa un anno mi hanno rubato l autoradio così ho deciso di rimontare l autoradio di serie unico inconveniente la Fiat non mi ha consegnato il codice (con assoluta certezza). Vi prego aiutatemii vi di il seriale Dell autoradio Fiat Panda Bp 638663654043 grazie in anticipo :blink:
code 1221
mandatemi il seriale dell' autoradio e io vi mando i cod.
meglio di cosii????
Ciao fiat stilo,
potresti aiutarmi nel ricavare il codice sblocco dell'autoradio della smart visto che, dopo aver cambiato la batteria, non trovo più il codice.
L'autoradio è un grundig di seguito metto tutti i numeri che ho trovato (giusto per non sbagliare)
CC0001200V007000000
MC1200 Y1575337
02108003301575337
Grazie in anticipo
PS: il codice l'avevo dato a mia moglie ma siccome il suo soprannome è "Smemoranda".... ho detto tutto
buon giorno a tutti
QUALCUNO MI PUò AIUTARE HO PERSO ILCODICE DELL'AUTORADIO DELLA MIA MULTIPLA ANNO 2008, I CODICI:
BP. 632565361739
FIAT186CDSB05
FIAT.N°7354360610
C0843
BLAUPUNKTGMBH
GRAZIE
ASPETTO UNA RISPOSTA MAURIZIO
ANTONELLACESERI@VIRGILIO.IT
Ciao e spero tu possa aiutarmi,
Ho smarrito il code dell'autoradio della mia Fiat Punto.
riporto tutti i codici che ho trovato sulle targhette perchè non so quelli necessari:
autoradio blaupunkt
fiat 199 mp3 my sb05
BP738672258649
BN nr. 7 647 386 316
fiat nr. 735 446 9710
grazie in anticipo.
Ciao sono Angelo e sono nuovo del forum, quidi scusami se sbaglio qualcosa, ho un problema con la mia autoradio Modello Ford 6000DE nemero Serial M005347, ti prego se puoi aiutami. Grazie comunque in ogni caso
code 6011 or 1526
Switch the radio on and the word CODE should appear in the display
Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter
